1995 Oldsmobile Aurora
1995 OLDSMOBILE AURORA
125,000 MILES • V8 • FWD • AUTOMATIC
DWICKS22
I have had this car for about 8 months. It has had various parts replaced nothing major, alternator, radiator, belts and hoses, etc. I was driving it a few days ago about a week after replacing the alternator and the tachometer would jump like it wasnt getting an accurate reading for a split second. it did this throughout the day. Then I went to the store everything was fine came out to leave the store and it wouldn't start. It doesn't crank and the fuel pump isn't running when you turn the key. you can hear all the relays clicking like it is supposed to when the car is started and i checked all the fuses. The security light doesn't stay on but the message center display and the outside temp display both flash when the key is in the on position. It has only done this when connected to a code reader. I have replaced the computer with a known good unit and nothing changes.
Oct 10, 2010 at 2:22 PM
Hi dwicks22, Welcome to 2carpros and TY for the donation
Is it cranking over and will not start or just won't crank over at all/nothing when you turn key to starting position??
Oct 10, 2010 at 9:53 PM
DWICKS22
nothing happens. I know the battery is fully charged. The starter dosen't even click like a dead battery and the fuel pump doesn't run for 2 sec like its supposed to. I can hear all the realays clicking on but nothing
Oct 11, 2010 at 12:46 AM
Okay-do this put it in park and turn key on-At the starter there's a purple wire on the small terminal use a screwdriver and short this terminal to the battery terminal on the solenoid-did it crank over-If so check and test the transaxle range switch and ignition switch-let me know
Oct 11, 2010 at 8:49 AM
