2004 Oldsmobile Alero transmision noise
54,000 MILES • 6 CYL • FWD • AUTOMATIC
WIDEGLIDE
I have a 2004 alero this car sounds like a plane going down the road or when i have it jacked up i have locked down the driver wheel the noise is still there i lock down the passanger side wheel it stops i have changed tires all wheel alinement change the bearing and the cv line and brake and rotors even with brake and rotors off and still makes this noise
Mar 9, 2008 at 12:53 AM
MERLIN2021
  • 17,250 POSTS
If you tried my suggestion, and had no result, you may have a bad carrier bearing in the differential, that's the part both axles plug into...
Mar 9, 2008 at 1:16 AM
