2004 Oldsmobile Alero missfire
WALT E
Engine Performance problem
2004 Oldsmobile Alero 6 cyl Front Wheel Drive Automatic 114k miles
engine miss between 2&3 shift sometimes. Have replaced plugs, wires ing moduel coil packs, replaced harmonic balancer, and crankshaft sensor.
Oct 5, 2010 at 7:27 AM
WRENCHTECH
  • 20,760 POSTS
If you are confident that you didn't damage any of the ignition components I would try having the injectors pressure cleaned professionally. Don't waste your money adding anything to the tank as it won't help/
Oct 5, 2010 at 7:43 AM
