2004 Oldsmobile Alero change oil light
2004 OLDSMOBILE ALERO
81,000 MILES • 4 CYL • FWD • AUTOMATIC
GRANNYWOO
i just had the oil changed and the change oil light won't go off can you help...i don't have the manual
thanks
Jan 19, 2009 at 3:28 AM
  • 110,244 POSTS
Hi:
Try this and let me know if it works.
Turn the key to the run position (do not start) then press the gas pedal to the floor 3 times and wait. You may see the light flash or hear a beep. wait for about ten seconds, then turn the key off and then back on to check if it reset.
Let me know if it works because there is another way to do it through the radio.
Feb 19, 2009 at 9:30 AM
