2004 Oldsmobile Alero
94,000 MILES • 4 CYL • FWD • AUTOMATIC
GBFAN79
I replaced the brake pad, rotors,and calipers.I bleed the brakes and got no bubbles.I know the system was open when i changed the calipers.Now when the car is on I get almost no brakes,very spongy.I have read online about a scan tool to open the abs valves?Any help is appreciated
Jan 1, 2010 at 6:11 AM
DOCFIXIT
  • 18,828 POSTS
Normally caliper replacement does not require ABS bleeding. If air has gotten into ABS then scan tool will be needed.
Jan 1, 2010 at 6:24 AM
