2003 Oldsmobile Alero Signal Flasher
2003 OLDSMOBILE ALERO
OLDSMOBILE
Electrical problem
2003 Oldsmobile Alero Two Wheel Drive Automatic 60000 miles
The turn signals sound comes on all the time without actually using the turn signal switch. It is only the sound inside the cabin no signals lights outside.
I replaced the flasher switch, which was very hard to reach behind the dash. Unfortunately, did not solve the problem.
I do not know what would be the cause of this problem if it is not from the flasher switch? What can be done to resolve this?
Jan 18, 2008 at 10:00 PM
DAVID KAM
[quote:10e626a32e="Oldsmobile"]Electrical problem
I do not know what would be the cause of this problem if it is not from the flasher switch? What can be done to resolve this?[/quote:10e626a32e]
Feb 5, 2008 at 7:32 PM
