2003 Oldsmobile Alero PLEASE HELP! LOW ON MONEY OR ID GIVE
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
NATE090692
i was driving on the interstate and my car, as it seemed, began losing momentum. almost like it was getting pulled or the engine was cutting off. but all of my levels are ood. imdue for an oil change but thats it. wat do you think might be the issue. i was advised that it might be the vaccuum in my engine line. but thats not professional advice.
Aug 5, 2010 at 10:24 PM
  • 75,988 POSTS
Lack of acceleration,surging,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below we start here.
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking,fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Aug 5, 2010 at 10:41 PM
  • 31,937 POSTS
Hi there,
when was the last time you had a tuneup & has the check light come on?
mark (mhpautos)
Aug 5, 2010 at 10:42 PM
