2003 Oldsmobile Alero lack of fuel
2003 OLDSMOBILE ALERO
KAMAKA
Engine Mechanical problem
2003 Oldsmobile Alero 6 cyl Two Wheel Drive Automatic
It has spark,compression,Pull the injector rail to check if injectors spraying have power to every connector wires.all 6s injectors are not spraying,but fuel pressure regulator leaking when cranking engine to see if injectors are spraying or not do i have fuel pressure regulator problem.or is their a problem that i have missed. Replaced fuel pump twice,fuel filter,fuses relay ok
May 16, 2010 at 6:37 AM
Hi kamaka, Welcome to 2carpros and TY for the donation
If the fuel pressure regulator is leaking it will flood the engine, if you use a noid lite to check the injectors and its not flashing there's a problem in the computer injector driver circuit
May 16, 2010 at 10:07 AM
KAMAKA
[quote:6cd0c28664="rasmataz"]Hi kamaka, Welcome to 2carpros and TY for the donation
If the fuel pressure regulator is leaking it will flood the engine, if you use a noid lite to check the injectors and its not flashing there's a problem in the computer injector driver circuit[/quote:6cd0c28664]what is driver circuit can you point the way to start checking the problem on the driver circuit,so far theres 2 injectors just dripping when cranking the car its not spaying how it should,did the noid lite its ok what would be the next step.Is their a ground problem.
May 18, 2010 at 1:26 PM
Noid lite flashing the driver circuit is doing its job-if the injector is not spraying fuel in a cone shape pattern its defective-You can try cleaning it and see what happens.
May 18, 2010 at 1:33 PM
