Engine Mechanical problem
2003 Oldsmobile Alero 6 cyl Two Wheel Drive Automatic
It has spark,compression,Pull the injector rail to check if injectors spraying have power to every connector wires.all 6s injectors are not spraying,but fuel pressure regulator leaking when cranking engine to see if injectors are spraying or not do i have fuel pressure regulator problem.or is their a problem that i have missed. Replaced fuel pump twice,fuel filter,fuses relay ok
May 16, 2010 at 6:37 AM
