2003 Oldsmobile Alero HOW TO ADJUST THE CLUTCH
2003 OLDSMOBILE ALERO
WADE_GILLIS
Transmission problem
2003 Oldsmobile Alero 4 cyl Two Wheel Drive Manual
I HAVE NO GEARS I LOST THE GEARS WHEN I WAS DRIVING does anybody know how to adjust the clutch when i jack up both tires off the ground i have gears i need to know how to adjust the clutch
Mar 7, 2010 at 7:03 PM
  • 31,937 POSTS
Hi there,
Do you still have clutch pedal pressure? is the speedo still working when in gear?, can you select a gear with out the clutch being used, is there any odd noises?
mark (mhpautos)
Mar 7, 2010 at 7:11 PM
