2003 Oldsmobile Alero help!!!!!
2003 OLDSMOBILE ALERO
11,800 MILES • 4 CYL • FWD • AUTOMATIC
SAMTATE
My car would not start half the time and occasionally dies going down the road and the chevy place told me to replace the fuel filter and we did and that didn't work and so then they replaced the pass lock cencor and it is still doing it and then they said to swap out the relays and we did and it is still doing it. what could be wrong with it???
Feb 24, 2010 at 7:45 AM
ERNEST CLARK
  • 1,730 POSTS
It's NEVER a good idea to replace parts until you get lucky and cure a problem. That dealer who has been advising you is a complete idiot.
Now, does you check engine light come on when you car dies??? If so, have your computer scanned for codes. This'll point you in the right direction. (If the computer says, example "O2 circuit fault", that doesn't mean replace the O2 sensor. It's only pointing you in a direction so you can check that system until you find the fault)
I suggest testing the crankshaft/camshaft positioning sensors. Again, check for proper operation before replacing.
Feb 27, 2010 at 11:07 PM
