2003 Oldsmobile Alero constant noise while driving
188,288 MILES • 4 CYL • FWD • AUTOMATIC
JGIN69
There is only noise when driving, coming from the front end. the noise increases when turning left and totally disappears when steering wheel is turned right. Can be heard at any speed and only is affected by the speed of the car and not RPMs. Since noise started both front drive axles and breaks have been replaced, have also rotated tires. Wheel bearings seem to be tight and in good condition. Have also put front end on blocks and ran car to 30 miles per hour while turning left and right, with no noise. The noise almost sounds like driving on the safety edges (drunk bumps) of the highway. Do you have any advice??
Jul 27, 2010 at 9:30 AM
  • 110,244 POSTS
It sounds like a bad right front wheel bearing. THat is where I would start.
Let me know what you find.
Jul 31, 2010 at 5:42 PM
JGIN69
[quote:8e5fe1ab6f="Jacobandnickolas"]It sounds like a bad right front wheel bearing. THat is where I would start.
Joe[/quote:8e5fe1ab6f]
Yes it ended up being the drivers side wheel bearing assy.
Aug 1, 2010 at 3:32 PM
  • 110,244 POSTS
That is what I thought. I'm glad you found the problem. Take care and let us know if you have questions in the future.
Aug 1, 2010 at 5:10 PM
