2003 Oldsmobile Alero code
96,000 MILES • 4 CYL • FWD • AUTOMATIC
TOWMOTOR
i have a serios problem i bought a scan tool
and it came up with the code #po300
it misfire on multible cylinders
what does that mean
Apr 2, 2009 at 3:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
It means 2 or more cylinders are not getting fire. You will need to inspect all spark plugs to ensure all are getting a healthy bright blue spark and also make sure fuel pressure is correct.
Thanks for using 2CarPros.com!
Apr 2, 2009 at 3:22 PM
TOWMOTOR
i understand that but what sensors or what else is involed in fixing the problem
Apr 2, 2009 at 3:35 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Many things can cause a misfire..the best place to start is the simple things such as the plugs, wires, coil packs.. Then you will go on to inspecting the sensors such as the crankshaft position sensor, MAP sensor and the crankcase ventilation system. Also check for vacuum leaks, exhaust system faults and fuel contamination.
Apr 2, 2009 at 3:50 PM
