2003 Oldsmobile Alero Bad fuel filter?
2003 OLDSMOBILE ALERO
65,000 MILES • 4 CYL • FWD • AUTOMATIC
BGRIFFIN24
Will turn over, but won't crank. Starts every once in a while. We replaced the starter with no luck. Attempted to reset the passlock, didn't work either. Gas cap is on tight. Fuel pump replaced 3 1/2 yrs ago. Fuses are good. Don't know what else to try. Any help would be much appreciated!
Aug 9, 2009 at 2:56 PM
  • 31,937 POSTS
Hi there,
You will have to check for spark and fuel flow & pressure, also get a scan done to check for any set fault codes, start here.
Mark (mhpautos)
Aug 9, 2009 at 3:46 PM
