2003 Oldsmobile Alero alternater
2003 OLDSMOBILE ALERO
130,000 MILES • 4 CYL • FWD • MANUAL
CLINTON801
my alternater went out 2 weeks ago i replaced it and chareged the battery worked great for a week replaced the alternater again tested the battery it tested good worked great for a week the alternater went out again this time i replaced the battery with the alternater. worked for one day the alernater is bad again but the battery tests good the fuses are good cant find any shorts,the plug end is in good shape no broken wires that i can see i dont know what else to do but change the alternater again.is there somethting tha im missing the is causing the alternater to go bad this fast?
Sep 22, 2008 at 3:52 PM
You need to have the computer field generation control circuit checked out
Sep 22, 2008 at 5:30 PM
