airbag cover removal
38,000 MILES • 4 CYL • FWD • AUTOMATIC
OTTRNLD
I am trying to repair the vinyl cover on the passenger aribag and need to loosen the cover. I have removed the glovebox and two screws which appear to hold the airbag assembly to a steel frame. I see no apparent way to loosen the airbag cover/door. Any suggestions?
Dec 29, 2009 at 3:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, there will be four bolts holding it in. which will be accessible from under the dash. Use a long 1/4 inch extension and a 10 mm socket. Also I don't know if you can replace the cover because it is made into the airbag. Please let me know how it goes.
Jan 12, 2010 at 3:52 PM
