2003 Oldsmobile Alero Adjusting Sunroof
2003 OLDSMOBILE ALERO
90,000 MILES • 6 CYL • FWD • AUTOMATIC
JAMES22
The sunroof has a lift & slide back feature. A few months ago, all of a sudden, it would not close completely. The sunroof would stay up about a half inch.
I see the torx screws to adjust but there is not enough play to adjust the back to come down 1/2 inch.
The slider on the left side [driver] does not retract as far as the right side but I have no idea why.
Can you make suggestions?
Thanks, Jim
Nov 6, 2008 at 3:14 AM
JAMES W.
  • 2,394 POSTS
It sounds like one side(driver's) is losing it's grip in the drive unit. If you can access the grear drive and remove the cover, you should be able to see what's going on.
Nov 6, 2008 at 4:32 AM
JAMES22
[quote:790aa245bd="James R. Weizel"]It sounds like one side(driver's) is losing it's grip in the drive unit. If you can access the grear drive and remove the cover, you should be able to see what's going on.[/quote:790aa245bd]
By gear drive I assume you mean what looks like a worm gear, a really long one, that is tucked in a long crevice. The plastic sleeve doesn't show any obvious way to get at it. Does that mean dropping the headliner to get at the cover and then the gear?
James
Nov 6, 2008 at 4:53 AM
JAMES W.
  • 2,394 POSTS
If you can't remove the drive unit through the access hole, then "yes" you will have to pull the headliner. It's a miserable job, but then you can clean and re-lube the cables at the same time.
Nov 9, 2008 at 11:24 PM
