Electrical problem
2003 Oldsmobile Alero 4 cyl Automatic 104000 miles
My 2003 Oldsmobile Alero's front passenger window will not go up or down using either the main window switch on the driver's door or the switch on the actual passenger door. All of the other windows work. They are power windows. My husband was using it around the time when it stopped working and he said he could hear a noise coming from the door like it was trying to go down but nothing happened. After a few tries, the door stopped making the noise all together and now all that you can hear when you lean your head against the door is a clicking sound when the window is tried. I am not sure if the problem is eletrical, the motor or the window regulator. Please help! If you can tell me what you think has failed in the window, that would be very much appreciated!!
Sep 29, 2009 at 4:49 AM
