2003 Oldsmobile Alero
KELLY SHACKLEFORD
Electrical problem
2003 Oldsmobile Alero 6 cyl Two Wheel Drive Automatic
eveytime u let it get to temp or drive it a couple miles .it will die on u. u have to clear the po101 code out it will run fine then it will do it again. it has a new mass air flow sensor on it.it has a pending code po101.when u clear it it will run fine 4 a couple of miles and do it again,then u start the prosses again.is it a ground or and ignition problem.any help where to start would be appricated.
Jul 14, 2010 at 3:10 AM
  • 110,248 POSTS
If the MAF is new, start checking wiring for corrosion, damage...
Jul 31, 2010 at 5:52 PM
