2002 Oldsmobile Alero WHITE SMOKE TEMPORARILY COMING FROM M
2002 OLDSMOBILE ALERO
152,000 MILES • 4 CYL • FWD • AUTOMATIC
MIKEJONES3974
OK. I CRANK MY CAR UP AND IT DOESNT SMOKE! BUT WHEN I LET IT SIT FOR A MINUTE THEN GET IN TO PULL OFF A WHITE CLOUD OF SMOKE COMES AND IT STINKS! WHILE IM DRIVING IT DOESNT COME OUT AT ALL! BUT WHEN I LET MY CAR SIT STILL THEN PULL OFF IT DOES IT AGAIN! SOME PEOPLE SAY ITS A VALVE SEAL LEAK! WHAT DO YOU THINK IT IS?
Jan 11, 2009 at 4:52 PM
  • 110,244 POSTS
Hi:
White smoke usually indicated a bad head gasket allowing coolant to get into the engine and burn. Are you sure it isn't steam from the colder weather? IS the car using coolant?
Feb 19, 2009 at 9:44 AM
