2002 Oldsmobile Alero turn signal noises
2002 OLDSMOBILE ALERO
BGIRL531
Noises problem
2002 Oldsmobile Alero 4 cyl Automatic 75,000 miles
The clicking sound of the turn signals stay on even after my signal is off and continues randomly when the vehicle is on. This happens daily..how come?!
Feb 16, 2009 at 6:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Suspect faulty signal flasher. Flasher is located right behind the hazard button on the dash. You can get to it by removing the shroud surrounding the speedo..
Thanks for using 2CarPros.com!
Feb 16, 2009 at 6:43 AM
