2002 Oldsmobile Alero Turn Signal
2002 OLDSMOBILE ALERO
126,000 MILES • 6 CYL • 2WD • AUTOMATIC
GIORDANO
My turn signals work ok, but when I turn them off, it keeps on clicking. the lights do not flash, just a relay clicking noise.. Is it the trun signal switch or the flasher relay?
Mar 16, 2009 at 4:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
Suspect a faulty turn signal flasher relay. Your flasher is located right behind the hazard button on the dash. You can get to it by removing the shroud surrounding the speedo gauge.
Thanks for using 2CarPros.com!
Mar 16, 2009 at 6:45 PM
