2002 Oldsmobile Alero Timing Chain
2002 OLDSMOBILE ALERO
113,000 MILES • 4 CYL • FWD • AUTOMATIC
BRENTRICHARD88
The timing chain shattered in my 2002 alero, dealership says i need a new engine ranging from $2200 - $4500. is it possible to just replace the timing chain to get the car running again? i have seen timing chain kits on ebay from $100 - $150. anyone's thoughts?
Jan 11, 2010 at 8:16 AM
DOCFIXIT
  • 18,828 POSTS
Chains don't normally shatter did engine sieze? is that why you need new?
Jan 12, 2010 at 2:22 AM
BRENTRICHARD88
They didn't really explain much to me and I didn't know what questions to ask. This is all they said "the timing chain blew all apart" they contacted GM and we're told that the motor would need to be replaced.
I had it taken there because it wouldn't start. I went to start the car like any other day, the car was turning over and then there was a pop like it was going to start, but it didn't.
I am taking it someone else for the repairs, figuring that if it does need a new motor as they said, so it should be less than what a dealership charges for parts/labor.
Jan 12, 2010 at 5:10 AM
DOCFIXIT
  • 18,828 POSTS
Your correct going with independent shop hope it is just chain
Jan 12, 2010 at 5:13 AM
