2002 Oldsmobile Alero intake manifold upgrade
2002 OLDSMOBILE ALERO
RONDELL99
Engine Performance problem
2002 Oldsmobile Alero 6 cyl Front Wheel Drive Automatic
i have searched every online for a high performance
intake manifold is it possible to upgrade it or does this
item not exist?
Feb 11, 2010 at 9:42 AM
ERNEST CLARK
  • 1,730 POSTS
I'd need to know which engine you have. But I don't suspect there's much available for you motor.
And are you sure you want a high-performance "intake manifold", or do you mean "Cold Air-intake"???
Upgrading an intake manifold by itself will do absolutely nothing, and may even hurt performance. (The MAF, injectors, exhaust and computer programming would have to be changed as well in order to work as a system)
Feb 27, 2010 at 11:26 PM
