2002 Oldsmobile Alero scan codes
2002 OLDSMOBILE ALERO
113,000 MILES • 4 CYL • 2WD • MANUAL
DAWNY33
I had my car towed home because the engine was shuttering...if I tried to drive it would try to stall, if I tried to climb a hill, all power was gone and would stall. We scanned with a universal code reader and the code was 300...any suggestions??? We changed sparkplugs and it looked like 1 and 4 were fouled but still no change
Feb 18, 2008 at 10:52 AM
MASTERTECHTIM
  • 4,750 POSTS
there is a coil that controls the #1 and 4 cylinder. replace the 1-4 coil and if it still stutters then also replace the ignition module. this will fix your car.
Feb 18, 2008 at 10:56 AM
