2002 Oldsmobile Alero radio
2002 OLDSMOBILE ALERO
118,000 MILES • 6 CYL • FWD • AUTOMATIC
JSHE6015
i installed a radio in this vehicle.... i accidentally touched two wires together... and now the tail lights and dash lights do not work.... i checked all the fuses and they are all good... what could this be.... is it a relay or something more serious?
Jan 31, 2010 at 7:36 AM
BLUELIGHTNIN6
  • 16,542 POSTS
most likely in line fuse has blown. you sure you checked all fuses and the in line fuses? BTW just looking at a fuse isn't considered testing it, you need to actually use a test meter on them to be sure.
Jan 31, 2010 at 7:47 AM
