2002 Oldsmobile Alero possible waterpump leak
2002 OLDSMOBILE ALERO
156,000 MILES • 4 CYL • FWD • AUTOMATIC
KUIPER_05
I tink my wter pump is leaking and was wondering wear it is and how to change it
Jan 17, 2009 at 8:15 AM
  • 110,244 POSTS
Hi:
The water pump is on the passanger side of the car mounted to the engine (aprox centered where the belt runs). There is a seap hole on the bottom. That is where is will leak if it's bad. Make sure because it's not a fun job.
Let me know what you find.
Feb 19, 2009 at 9:32 AM
