2002 Oldsmobile Alero p0300 error code
138,000 MILES • 4 CYL • 2WD • AUTOMATIC
JAASSOONN
i have p0300 error code on my car. what is definate thing i need to fix for this to go away. ive heard many things but what is the exact thing i need to fix for this problem to be fixed
Dec 10, 2008 at 12:56 PM
  • 110,248 POSTS
Hi:
It sounds like there is a problem with the O2 sensor. The only way to be sure is to have the sensor checked. It may be good and something may be wrong with the circuit. I wish I could be more confident and say replace the sensor, but it may not be the problem. The codes provided only point you in the direction of the problem.
Let me know if this helps.
Dec 18, 2008 at 7:35 AM
