2002 Oldsmobile Alero Olds Alero Head gasket leak
89,000 MILES • 6 CYL • FWD • AUTOMATIC
JOHN M55
The head is leaking coolant externally and into the oil. My local mechanic says it is a fairly common problem with this vehicle type and has to do with the difference in expansion rates between the block and aluminum head. Short of getting a new motor, what are my options? Thanks in advance.
Aug 18, 2008 at 2:05 PM
SERVICE WRITER
  • 9,123 POSTS
Do a head gasket job.
How long has this been going on?
Don't rule out a possible intake gasket. I would suggest confirming this is a bad headgasket.
dexcoolsettlements.com
If this is fairly fresh, just replace the head gaskets if that's the problem. Get the heads shaved too.
Aug 18, 2008 at 2:17 PM
