2002 Oldsmobile Alero Hope you can help
2002 OLDSMOBILE ALERO
111,000 MILES • 6 CYL • 2WD • AUTOMATIC
JCWENDLER
Just replaced the spark plugs and spark plug wires. I start the car and the engine starts reving uncontrolably. my foot is no where near the gas peddle, the peddle not moving. I don't won't to leave it running so I can look and trouble shoot cause it seriously sounds like the car is going to blow up. I took a quick look at the engine and it looked like it was going to jump off the mount. Rev up, go down, rev up, go down. I double checked the spark plugs and firing order and all is good with the parts. Still you can tell me the firing order, so I can tripple check. Please let mr know if you need any other info.
May 12, 2009 at 9:13 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Order 1-2-3-4-5-6 cyl 1-3-5 towards bulkhead 2-4-6 cyl front. Check to see if you might have knocked someting loos connector etc. Check to seee if throttle cable is opening plate.
Let me know
Thanks for donate
May 12, 2009 at 9:24 AM
