2002 Oldsmobile Alero clicking sound
OLDS ALERO
Electrical problem
2002 Oldsmobile Alero 6 cyl Front Wheel Drive Automatic
The clicking sound from the hazard switch when the turn switch and hazard switch is in neutral is caused by dirty turn switch contacts in the muliti-fuction switch.
Take it out clean off the contacts and the problem goes away.
Thanks to Lizreed for helping me on this!!!!!!
Jul 19, 2009 at 12:07 PM
DANAUTHIER
  • 156 POSTS
You more than likely have a faulty hazard lamp switch, quite comon with GM "N" body vehicles. A clicking noise or turn signals not working are the usual suspects when the switch is failing.
The switch is, last I knew, a dealer only item and was not too expensive and easy to replace.
Jul 19, 2009 at 12:28 PM
OLDS ALERO
Do not buy a new hazard switch. The hazard switch is just responding to the inputs from the dirty turn signal switch.
Jul 19, 2009 at 7:16 PM
