2002 Oldsmobile Alero Air Conditioning Drain
FENWIKI
Air Conditioning problem
2002 Oldsmobile Alero 4 cyl Two Wheel Drive Automatic
My air conditioning drain seems to be clogged. Water will pool in the drive side floorboard. Where is the drain located under the car and how do I clean that out?
Aug 23, 2008 at 12:25 AM
MERLIN2021
  • 17,250 POSTS
You need to jack it up and where the firewall and the heater/a/c plenum meet is where the drain is, use a small piece of wire, and clean it out, don't push too far in, we dont want to puncture the evap core...then use a computer duster to blow some air in it to finish the job...
Aug 23, 2008 at 1:22 AM
