2001 Oldsmobile Alero Warning lights on: Check vehicle, ABS
2001 OLDSMOBILE ALERO
133,000 MILES • 4 CYL • FWD • AUTOMATIC
TYAH30
Was driving yesterday, when suddenly, all three warning lights came on simultaneously. Turned the car off, then restarted and the same lights came back on. The car is running fine. Not sure where to even begin to look. What do you think the problem could be?
Feb 13, 2009 at 12:09 AM
  • 110,240 POSTS
Hi:
It sounds like a sensor set a code. What I recommend it to take the car to a nationally recognized parts store and have them scan the computer for codes. Many do it for free and you will know what direction to go in.
Let me know what you find.
Feb 19, 2009 at 8:40 AM
TAXICABFOUR
Been the done that . Does your front wheels sound too loud like an airplane taking off? My 2004 Alero had all the lights come on at once. I had to replace both Front Wheel Bearing Assemblies. That what was making the nosie and it cured my issues with the warning lights coming on ( abs and brakes) . It is a common problem. Try to get the parts online (it`s Cheaper than dealer price)
Feb 21, 2009 at 4:17 AM
TYAH30
Thank you for your suggestions, Jacobandnickolas and taxicabfour!
I took your advice and had the car scanned for codes. Turns out, I have to have the FR wheel bearing and tie rod end replaced. I haven't heard any noise at the wheel yet, but I'll get it worked on ASAP. Found out I also need to get the serpentine belt replaced. Luckily, I know a mechanic who can fix both these problems without my paying for more than the cost of parts, which I will be checking online for. I really appreciate your feedback. Thanks again!
Feb 23, 2009 at 12:33 AM
