Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Oldsmobile
Alero
Brakes
Caliper
Replace/Remove
2001 Oldsmobile Alero Replace Breakes
2001 OLDSMOBILE ALERO
61,000 MILES • 6 CYL • 2WD • AUTOMATIC
AFTERFOREVER
MEMBER
1 POST
How do I remove the front calipers? I removed the two bolts but it will not come off.
Apr 12, 2009 at 1:36 AM
BLACKOP555
Experienced Mechanic
loosen beeder valve and compress the caliper with a large c clamp. then remove the clamp and it shoudl be loose and easy to pop off.
Apr 12, 2009 at 2:18 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine overheating
