2001 Oldsmobile Alero random cylinder misfire code
ED43512
MEMBER
2001 OLDSMOBILE ALERO
4 CYL
FWD
AUTOMATIC
122,000 MILES
What could cause this to happen? Random cylinder misfire? Where is the ignition coil housing on this vehicle?
Tuesday, December 9th, 2008 AT 4:53 PM
RADAR4230
MEMBER
1 POST
We have a 2001 with 80,000 it was missing but not throwing a code. I changed plugs, didn't help. I then changed the coil housing and plug boots. These are located under the curved AL piece that covers the valley between the two overhead cams. I hope this helps some. This fixed our miss fires.
