2001 Oldsmobile Alero Problems
2001 OLDSMOBILE ALERO
13,200 MILES • 6 CYL • FWD • AUTOMATIC
YOUMINMC
I am driving this alero and it continues to give me problems. I have changed the bearings quite a bit since I have been driving this car. I am almost certain that it is not a bearing problem. I have also noticed that my brakes wear out quite a bit as well. It is making a rubbing noise when I turn the vehicle to the left. It also makes a squeaking noise. I will also be driving down the road and it will all of a sudden just want to vear to the left. I wasnt sure if maybe the problem might be a bad caliper? Do you have any idea what this might be? Thanks
Dec 17, 2008 at 6:33 AM
  • 110,244 POSTS
Hi:
A stuck caliper could be your problem. Remove it and see if both the slides and piston move freely. Let me know what you find.
Dec 18, 2008 at 7:15 AM
