2001 Oldsmobile Alero problem with my Alero
NFLORES06
  • 2001 OLDSMOBILE ALERO
  • 6 CYL
  • 4WD
  • 108,000 MILES
I have a 2001 oldsmobile alero with 108000 miles on it. My car's with my uncle who is a mechanic and I had him check my car because I was told last month when I went to get an oil change that my intake manifold needed to be replaced. The mechanic from the shop wanted to charge me $600 just for the parts. That alone made me wonder. Few weeks later which was last week, my service vehicle soon light turned on. My uncle says the intake gasket is fine. He cleaned it up. I asked him to give my car a tune up as well. Is there a possibility that there was a problem with my intake or is it normal that there was oil on the gasket and just needed to be cleaned? Also my car tried to play "dead" and wouldn't turn on. I was told to put my key on "ON" for 20 mins which I did and my car turned on. I had a mechanic try to install an alarm to fix the problem and he says it wouldn't reset the security, and that's when I was told I needed to get a whole new ignition. Is that true? Could that be the problem why my car cranks sometime when I turn it on? By putting a new ignition will that solve my problem with the cranking?
Friday, March 26th, 2010 AT 6:08 PM
  • 109,867 POSTS
Chances are your uncle is correct and there was just a build up of oil on the intake. However, it the check engine light came on, I would have the computer scanned to determine what caused it to come on.
As far as the key, by letting it on for 20 minutes, you bypassed the security system. All I can say is that if the secrity light is on, the only place that will have the proper equipment to test it would be a dealer. It could be something as simple as the sensor in the key is bad, but they need to check that.
Wednesday, April 7th, 2010 AT 1:13 PM
NFLORES06
Thanks. My uncle checked it and it was just oil that was on top of the intake and he cleaned it. Nothing was wrong with the intake. Thank God. As for my ignition well i'm still working on it. I'm letting my uncle take my uncle again in the next couple weeks for him to take a look at the ignition so hopefully it don't cause me an arm and a leg.
Wednesday, April 7th, 2010 AT 2:21 PM
  • 109,867 POSTS
Let me now what you find.
Wednesday, April 7th, 2010 AT 4:11 PM
