2001 Oldsmobile Alero leaking antifreeze
CALVINJ
  • 5 POSTS
Engine Cooling problem
2001 Oldsmobile Alero 6 cyl Two Wheel Drive Automatic
my oldsmoble lero is leaking atifreeze from this housing that is conected to the water pump.what is the cause.[img:ed8147da31]http://www.2carpros.com/forum/automotive_pictures/561250_car_part_1.jpg[/img:ed8147da31] how do i repair it.
Aug 13, 2010 at 7:36 AM
BLUELIGHTNIN6
  • 16,542 POSTS
gasket between water pump could be bad
Aug 13, 2010 at 7:40 AM
CALVINJ
  • 5 POSTS
[quote:8afb5b0057="bluelightnin6"]gasket between water pump could be bad[/quote:8afb5b0057]the gasket on the water pump itself is good.is there a gasket on this housing that is connected to the water pump.
Aug 13, 2010 at 8:05 AM
BLUELIGHTNIN6
  • 16,542 POSTS
should have an O-ring seal, yes.
Aug 13, 2010 at 9:49 AM
