HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Oldsmobile
Alero
Engine Cooling
Leak
SPONSORED LINKS
2001 Oldsmobile Alero leaking antifreeze
CALVINJ
MEMBER
2001 OLDSMOBILE ALERO
Engine Cooling problem
2001 Oldsmobile Alero 6 cyl Two Wheel Drive Automatic
my oldsmoble lero is leaking atifreeze from this housing that is conected to the water pump.what is the cause.
how do i repair it.
SPONSORED LINKS
Friday, August 13th, 2010 AT 2:36 PM
BLUELIGHTNIN6
MECHANIC
Gasket between water pump could be bad
Friday, August 13th, 2010 AT 2:40 PM
CALVINJ
MEMBER
The gasket on the water pump itself is good. Is there a gasket on this housing that is connected to the water pump.
SPONSORED LINKS
Friday, August 13th, 2010 AT 3:05 PM
BLUELIGHTNIN6
MECHANIC
Should have an O-ring seal, yes.
Friday, August 13th, 2010 AT 4:49 PM
Please
login
or
register
to post a reply.
Related Leak Content
Ran Into Coolant Leak In Alero, Not Sure What It Is
My Friend Was Driving Car Around With It Being Low On Coolant I Suppose. She Just Got Her Oil Changed And All The Fluids Should Have Been...
Asked by
Christian Carpenter
1 ANSWER
2001
OLDSMOBILE ALERO
VIDEO
Cooling System Pressure Test For Leaks
Instructional repair video
GUIDE
Coolant Leak Symptoms
When your car begins to leak coolant the first indicator is the engine will start run hot and possibly overheat. This will be noticed by the driver by observing the...
2001 Oldsmobile Alero Leaking Antifreeze And...
When I'm Driving My Car Starts To Over Heat I Pulled Over To Check The Antifreeze And It Was Full When I Parked It Some Time Over The Night...
Asked by
alyxxg
1 ANSWER
2001
OLDSMOBILE ALERO
Hello, I Recent Began To Have A Leak In My Engine Coolant. The Problem Is Though That Its Coming From What Seems To Be The Engine Itself. I...
Asked by
Marioj1
2001
OLDSMOBILE ALERO
Alero Coolant Leak!!!
My 2000 Oldsmobile Alero 2.4l Has A Repeating Coolant Leak. I Can't Seem To Locate It. Had The Waterpump And Thermostat Replaced And It...
Asked by
rlbutta16
2 IMAGES
2000
OLDSMOBILE ALERO
Coolant Leak From Thermostat Gasket
I Had A Mysterious Coolant Leak Last Year And It Was Tough To Find. I Thought It Was The Water Pump. Turns Out The Threads On The Surge Tank...
Asked by
Sneakfox
2 IMAGES
2000
OLDSMOBILE ALERO
VIEW MORE
SPONSORED LINKS
Online car repair manuals
