2001 Oldsmobile Alero Help with brakes
2001 OLDSMOBILE ALERO
118,000 MILES • 6 CYL • 2WD • AUTOMATIC
The car is running out of brake fluid fast and the brakes become hard and you have to stop to get the car to stop. Tryed refilling fluid and it does good for a couple of weeks. What should i do and how much does this type of thing cost?
Dec 18, 2008 at 5:20 AM
DOCFIXIT
  • 18,828 POSTS
You need to find the leak wheel cylinder, caliper or master cylinder. Until problem is located can't say what it will cost.
Dec 18, 2008 at 6:43 AM
