TRUMP48
Electrical problem
2001 Oldsmobile Alero 4 cyl Front Wheel Drive Automatic
the headlights, radio and dash indicators do not operate after starting the engine. They all magically start working after a few minutes of driving. this is a Canadian car and has about 110,000 kms. is it ok to continue driving it? will the problem intensify? I think the BCM may need replacing. Your expert opinion would be most appreciated.
Mar 22, 2010 at 9:18 AM
LEGITIMATE007
  • 5,121 POSTS
I think you know exactly what your talking about with the bcm, the mileage is nothing, thats like a new car a hundred thousand. nothing, some of the bcm terminals may be a little corroded from the heat and humidity. over the years, but they can be cleaned. I would also check the fuses first. before going for the bcm
Mar 27, 2010 at 5:09 AM
