2000 Oldsmobile Alero window
2000 OLDSMOBILE ALERO
109,000 MILES • 6 CYL • 4WD • AUTOMATIC
TRELLR
Hi. I've got a problem with my two front windows. A few months ago my passanger side window just went out. Then last month my driver side window did the same thing. I was wanting to know if it could be the motor. When you try to roll them down you can hear a clicking noise.
May 7, 2009 at 3:30 PM
2CARPRO JACK
  • 11,533 POSTS
If you can hear the motors running it is probably the regulators that have broken.Fairly common problem, but to be sure removal of door panel is required
May 9, 2009 at 5:18 AM
