2000 Oldsmobile Alero turn signal switch
JUSTANOTHERNAME
Noises problem
2000 Oldsmobile Alero 4 cyl Automatic 86000 miles
Sometime back it happened that when I would give a turn signal ( especially left), after the turn, the clicker sound would not go away and actually click at twice the speed for about 30 seconds on and off and stop. When this got worse, I took in to a shop. The guy replaced the switch ( it seems to be connected to the hazard switch). He has done it 3 times now and the problem is still there. With the last replacement, now I don't even have to be turning for the clicking to start. It happens whenever, especially when braking....
Apr 15, 2008 at 7:06 AM
  • 75,988 POSTS
Get your mechanic to look for a short circuit no more replacing flasher/switch
Apr 15, 2008 at 7:24 AM
