2000 Oldsmobile Alero Tie rod ends - replacement.
2000 OLDSMOBILE ALERO
106,425 MILES • 4 CYL • FWD • AUTOMATIC
LINDYMANN
Hello !
Thanks for reading this posting. I have a question aboutTie-rod ends (left-outer) being replaced. Is this unusual for this part to wear down?
I thought they would pretty much last the life of the car.
Thank You,
Mark
Mar 31, 2010 at 6:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
no it's not unusual , they have a lot of wear and tear to endure, not a bad idea to inspect then every so often and replace as needed.
Mar 31, 2010 at 7:02 AM
MERLIN2021
  • 17,250 POSTS
Nope! You are lucky to have gotten 106,000 miles out of it. They do wear out!
Mar 31, 2010 at 7:03 AM
LINDYMANN
Merlin2021 and bluelightnin6 !
You guy's ROCK ! !
Thanks so much for comments. Now I can go the mechanic who services the car. I was told about the tie-rod from a tire shop.
Which is why I thought I get a 2nd opinion !
[quote:bc3b9734ff="lindymann"]Suspension problem
2000 Oldsmobile Alero 4 cyl Front Wheel Drive Automatic 106425 miles
Hello !
Thank You,
Mark[/quote:bc3b9734ff]
Mar 31, 2010 at 7:52 AM
MERLIN2021
  • 17,250 POSTS
No problem, good luck with it!
Apr 1, 2010 at 6:26 AM
