2000 Oldsmobile Alero thomstate
WOODKNOT
Engine Cooling problem
2000 Oldsmobile Alero 4 cyl Two Wheel Drive Automatic
thomstate location ware is it.
Apr 7, 2010 at 4:33 AM
  • 110,248 POSTS
If you follow the upper rad hose back to the engine, it should lead to the t-stat housing. It should be under there.
Let me know if you find it.
Apr 7, 2010 at 5:00 AM
WOODKNOT
i looked at the rad. and found a hose on the driver side and follow it to a housing that had a sencer and two clamp hoses and one small hose with a o ring. i removed this and found nothing the housing had only a o-ring. i guess i pick the wrong hose or the car has no thermostate.
Apr 8, 2010 at 1:18 AM
  • 110,248 POSTS
It has one. See if this helps:
https://images.2carpros.com/forum/automotive_pictures/249084_thermo_1.jpg
Let me know if this helps. Joe
Apr 8, 2010 at 6:42 AM
