Engine Cooling problem
2000 Oldsmobile Alero 4 cyl Two Wheel Drive Automatic
thomstate location ware is it.
Wednesday, April 7th, 2010 AT 11:33 AM
MECHANIC
If you follow the upper rad hose back to the engine, it should lead to the t-stat housing. It should be under there.
Let me know if you find it.
SPONSORED LINKS
Wednesday, April 7th, 2010 AT 12:00 PM
WOODKNOT
MEMBER
I looked at the rad. And found a hose on the driver side and follow it to a housing that had a sencer and two clamp hoses and one small hose with a o ring. I removed this and found nothing the housing had only a o-ring. I guess I pick the wrong hose or the car has no thermostate.
