2000 Oldsmobile Alero soft peddal after new pads
2000 OLDSMOBILE ALERO
100,000 MILES • 6 CYL • FWD • AUTOMATIC
GAMESTER2K
i replaced pads and got in car and pumped brakes about 8 x , the pedal wold go in little over half way down , started car just in case, i think i dont think calipers were out to pads , how can remendy this problem i tried to back up to adjust , bpulled ahead , applied brakes , i did this 2x , still goes over half , do i bleed them and is there a certain way to do it , this thing tells me even when tire pressure is low , when to change oil so on ect . can you give me any advice on if i need any special methods , i am mechancakky inckined and know typical bleed , so any advice wound be greatly appreciated
thanks a bunch for your time.
Perry
Apr 10, 2008 at 6:02 PM
Bleed the brake system
Start with the brake master cylinder then RR/LR/RF/LF-
Apr 10, 2008 at 6:32 PM
