2000 Oldsmobile Alero service brakes light
2000 OLDSMOBILE ALERO
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
BRUCESCOTT
The service brakes light came on
I checked the front and rear brakes.
The back brakes needed changing
I put knew rotors and brake pads on that I purchased from Parts source
after the job was complete I reset the service light button.
The light would not go out
I then disconnected the battery cable for a few minutes
and then reconnect it
afyer goung for a test drive the service brakes light came on in a few minutes
I did have a little problem getting the calipers over the emergency brake on the back right hand side
How can I get the brake service light to stay off?
Mar 12, 2008 at 3:12 PM
MERLIN2021
  • 17,250 POSTS
Check the fluid level in the master and fill to line! DOT3 ONLY!
Mar 12, 2008 at 3:31 PM
BRUCESCOTT
I have already done that.
It is not the problem
Mar 13, 2008 at 8:07 AM
MERLIN2021
  • 17,250 POSTS
This is the RED light on the dash? the only other thing that will cause JUST that light is going to be the parking brake switch.
Mar 13, 2008 at 12:41 PM
BRUCESCOTT
where is the parking brake switch and what do I do to fix it?
Mar 13, 2008 at 1:48 PM
MERLIN2021
  • 17,250 POSTS
That depends on fi you have a pedal for it or a hand pull in the middle? The switch will be on the end or contact point, when the lever is at the off, or rest position, try pushing the contacts closed, if the light goes out, the parking brake needs adjustment to tighten the cables, or a cable replacement might be needed!
Mar 13, 2008 at 2:11 PM
BRUCESCOTT
I checked the switch on the brake pedal. The alarm light did not go out on the dash.
Took the back wheels off and rechecked installation .
The light on the dash is still on
Mar 15, 2008 at 9:27 AM
MERLIN2021
  • 17,250 POSTS
If the switch is good, and the brake system has no leaks...how is the pedal? Then you may need to have the instrument cluster tested...
Mar 15, 2008 at 11:12 AM
JAKEDASNAKE
There is a sensor in the brake reseivor tank. Pull the sensor out and see if the light goes off.
Nov 24, 2008 at 2:00 PM
