2000 Oldsmobile Alero rpm
VIRESH679
2000 Oldsmobile Alero Front Wheel Drive Automatic 125000 miles
Hello. The RPMS in my car are kind of high. When Im in park or neutral the RPMS raise to about 1.5 to 2. When Im driving and i let go of the gas the car maintains speed because the RPMs are higher. I also noticed the engine temerature is a little higher than usual. Also when braking I have to floor the brake harder because the RPMs force the car foward. Thankyou
May 12, 2009 at 2:30 PM
LEGITIMATE007
  • 5,121 POSTS
have your throttle position sensor checked, it could be faulty. I take it there is no check engine lights on, so I will rule out a vacuum leak
May 12, 2009 at 2:54 PM
