I have a 2000 Oldsmobile Alero V6. The vehicle is overheating at low speeds. Constant stopping or driving at low speeds cause the temperature to rise. I am constantly running the heat so that I don't overheat the engine. Another odd problem that is occuring suddenly is the idle is rough. I have looked to see if any coolant is leaking or if I need to add any, but nothing seems to be leaking. No real noticeable problems under the hood. I can not be certain that the fan is always starting, but when I push the A/C on, the fans both run. I am just trying to diagnose the problem before I start replacing items. Any advice would be appreciated.
May 23, 2010 at 7:13 AM
